Mitchel overdrives
I have one in my Phaeton. I like it as it gives you many choices for varying slopes and road speeds.
My Mitchell is a 26% and I have a 4-11 rear end ratio. I have had it in my car for over 80,000 miles...no issues.
Good Day!
I have a Mitchell 26% with a 3.78 rear. Great for touring. Very relaxed RPM at 50 MPH. I generally just go 1st -3rd and then 3rd OD. But on a long hill sometimes 2nd OD is useful.
Have one in my Roadster. I was trying to get more wiggle room by removing the extra lever and using the cable shift. No issues with that and now I can get across the car to exit on the curb side if I like. I'm running a 26% OD with 3:54 rear end and 600 X 16 tires. I love the combo so much I have ordered the syncro ****** so my bride can get us home if the need arrises. You'll never be sorry if you intend to drive your car. 6 forward and 2 reverse. I have used only 5 of the forwards but if I ever climb Pikes Peak, I understand the first over is a useful gear. Good to have all these choices and keep the rpm down some. A 56 Ford F100 steering box and a short pitman arm has really made my car a pleasure to drive. (Not so much in the rain.)
Excellent unit.
26% w/3.78
Sue, & Steve, could not be any better to deal with if you have a problem!
Loubob
I've bought three of them. Picked up the last one at their place of business a few miles east of I-5 in central Calif. on my way back from a trip to So. Calif. I have one in my 31 SW Cabbie along with "B" motor, I can drive all day long at 60MPH+. The last one I got for my Briggs fordor leatherback but haven't got around to installing it yet. Been thinking about one for my 35 Ford cp. also.
I have one in my '31 Dlx Coupe and LOVE it. Although truth be told, I have not really had a chance to use it much, as all my driving is around town - no long distance trips yet.
But in the short term - it is like having 4-wheel drive that you don't need to use it very often, but when 4-wheel drive would make a difference, it is really nice to have!
I have the 26% over-drive and 3.54:1 rear ratio and high compression head. Love it, no negatives to report.
Have had mine for about 10 years now, and would never own a Model A without one. I also have the 26% and 3.78 rear end, which I find about ideal for Southern California. It is so easy to use.....basically like a much needed 4th gear. I use it all the time, even on our surface streets. After I hit 40+ mph, I shift into OD. On the freeway, I like to cruise effortlessly at 60 mph, but the real fun is using it at around 45/50......the car is so quiet it is amazing. And for driving in our local mountains, 2nd OD is perfect. The added lever has never bothered me, as I never seat 3 in the front seat. Bullet proof and extremely well built........
Excellent addition for the Model A. I'm running the 33% with 3.78 rear end in my heavy slant window sedan. Don't know why you would use a 26% when the 33% reduces the engine RPM which means less wear. Have installed about a dozen 33% in customers cars and they all love it. Just my experience.
Arlen---If I was just touring, I would probably use the 33%, but in my opinion, and that of many others, the 26% is a good compromise for all around driving. Tom Endy has one of his Model A's with a 36% (if I remember correctly), and he told me it was higher than he liked. Like almost all Model A items, whatever works well for you is what you should use. Others think a well running Model A doesn't even need an OD at all.
My overdrive is not a Mitchell, (F-150 Tremec) but the 27% in my pickup with 3.78 rear is just about perfect.
I have one in each of my 3 Model As. Love 'em. When combined with one of Mitchell's synchro gearboxes, simply brilliant. I have fitted a cable change to one of them and will make at least one more. Touring at 50 is no strain. Both the engine and I are relaxed.:D
I have the 26% Mitchel over-drive with a 3.54 rear, a BF 5.9 head high compression head, and a Stipe IB30 cam. Performance is great, I can run 55-60 all day long and can climb the hills in West VA, western Maryland, and Pennsylvania with no problems. I should have done it many years ago. Love it.
