Karl
A quiet day at work today so I thought I would share with you a new to me miss and cause in my 34 Fordor .
Recently I attended an Art Deco festival about 2 hours drive north of were I live We took the 34 and driving up everything was great apart from the odd stumble . Coming home the car was missing quite a bit . Seemed to be ok below 50 mph but much worse when I pushed it a bit.
My initial thoughts were condenser or coil or perhaps fuel
I replaced the condenser and coil with no real improvement. I did notice a little bit of sediment in the glass filter of the (later than 34) fuel pump and wondered if there was gunk in the carb- I changed out the carb for my spare one. No Improvement so I started form scratch.
What I found was that the cap on the vacuum plunger on the distributor had worked loose by vibration. Hence the vacuum brake was not working -Tightened up and the problem is gone !
I've often wondered if the vacuum brake was needed with modern fuels -I now know it is!
Karl
Karl
