In the early part of the video in post 110 it looks like the #1 spark plug is firing between the base of the porcelain insulator and the steel spark plug base. I.E. the plug is shorted to ground. You can see the spark jumping.
I agree that there is a stray spark arcing in area of #1 plug.
Look closer while running in dark garage to track down stray spark.
I sometimes see the brass spark plug "wire" where it connects to distributor terminal, juggling around at same time as that flash near #1.
Also there are drops of water coming out tail pipe. This tells me that engine is NOT warmed up.
I will bet that plugs are fouling ... this will cause the missing.
I saw this MANY times with cars in 50s and 60.
Too much idling and short trips where engine never warms up will foul plugs every time
You can clear up fouled plugs by running the car for 15 or 20 minutes at speeds of 35 or 40. A 10 mile run at 45 is even better.
Old time Mechanics in 50s called it "blowing out the carbon".
When checking plugs remember to look at the Porcelain part of plug.
Ignore the "steel ring" on plug it will be black because that area never gets as hot as the Porcelain.
Porcelain should be gray or brown or tan color.
It is normal for steel "ring " on bottom plug to be black.
I would not expect any OLD TIME engine that is idled for long periods and never warmed up to idle correctly.
This never happens with newer cars because computers control mixture.
My 1969 and 1973 Electronic Fuel Injected VW Fastback did not foul plugs.
This car has a computer that controls fuel injectors.
