Diastole
Sounds mechanical to me, not electrical. Particularly if you can here it at tailpipe. Perform a leakdown test on all four cylinders. It is a simple test similar to compression. That will test your springs, headgaskets, valves and valve seats, as well as rings. It can also help with diagnosing carbon deposits that can by itself cause detonation.
The erratic vacuum is the tip-off. Assuming gauge is correct.
Perform it cold and on a hot engine.
You will need compressed air and a quiet place if the gauge measures more than 25%. A leakdown tester can be rented from most good autoparts stores. You will need either a TDC whistle or a crank to move the engine. Remember to remove all four plugs during test.
Reply with the percentages for each cylinder to help narrow cause if it is a positive leakdown test.
Good luck,
Diastole
Good luck,
Diastole
