Fairlane514
29 Tudor
Here's what I have done to chase the misfire.
Set points (.020) use NuRex wrench to set timing
New plugs Champion W18 gapped .035
Zenith carb rebuilt
Wiring all good
New condenser NAPA FA-82
Coil ohmed at 1.5 and 7500 secondary side
Alt is charging
Compression check, 60psi on all cylinders
Valve check by removing schraeder valve from compression gauge and do 10 cycles of each cylinder.......all four cylinders pumped up to 60psi each cycle without hesitation. Trying to test for a possible bad valve guide not letting valve return square to seat and cause issue.
It starts up with ease and idles but has a definite misfire that is not rhythmic. My vacuum gauge shows needle bounce down from 21 to 18 or so, randomly.
When a listen at tail pipe (new muffler) I can easily hear the misfire.
The distributor shaft is not loose or wobbly and it has the NuRex points plate and new style points/condenser.
Have not tried new coil
Fuel is fresh with some Marvel in it as well as the oil.....one quart of Marvel.
When driving really not a noticeable misfire by feel, but can hear it.
Zenith carb rebuilt
Wiring all good
Alt is charging
