Miscellaneous Model A Parts
JRrev
Frenchtown Twnshp
MI
Price
In Ad
Here are miscellaneous Model A Parts for sale:
Gas valve-original $17.50
Pitman arm-original $10
Generator pulley-original-'30-31 $10
Brake shaft brace-original - $10
Clutch arm-original (early)- $25
Rear fender brackets-original-sedan pair $22.50
Trans gear-1st./rev.-MARK "the good repro"- $45
King pin RH-original used, very little wear- $10 ea.
Dealership Advertising booklet-$15
Door handles - outside - originals- $10 ea.
Brake adjusting wedges- re-cad-originals $40 set of 4
Door handles - outside originals- $10 ea.
Speedometer gear on driveshaft-original- $15
Brake adjusting wedges - re-cad originals- $40
Schrader tire gauge- $20
Seamed gas lines - '30-31- $25 ea.
All plus shipping.
Note: Fuel valve's cone is stuck so not sloppy worn but likely needs rebuild kit. Pitman arm has some wear on ball. King pins unavailable.
