bobgreco
- City
- Brookfield
- State
- WI
- Price
- offers
I have a few miscellaneous ford tools that I would like to sell. Generally, they are all in nice shape with some surface corrosion and normal wear and tear. I have pictures available upon request. Please make me an offer for any or all. Shipping will be what I actually pay. Usually around 4.75 for a USPS flat rate box, but other arrangements can be made.
Item A - Vintage Original Ford Model A Starting Crank (A-17036B)
This is a vintage Ford Model A starting crank. I believe this is the last in the series of Model A cranks part number A-17036 B and was used from December 1929 to the end. It has a 13/16” lug wrench on one and and has in-line pins and a 7 ½ “ throw. It has no markings and other than some rust pits on the crank end, it is in very good shape. It shows signs of normal wear from usage.
Item B - Vintage Original Ford Tool Wrench M-01A-17017B
This is a vintage Ford script double ended box wrench. It is cast with Ford (script) USA – M- 01A-17017 B on the bottom side. The top side says nothing. It has very little corrosion and no pitting at all. It shows signs of normal wear from usage.
Item C - Vintage Original Ford Tool Wrench 01A-17017B
This is a vintage Ford script double ended box wrench. It is cast with Ford (script) USA 01A-17017 B 83 on the bottom side. The top side says nothing. It has a little surface corrosion and no pitting at all. It shows signs of normal wear from usage.
Item D - Vintage Original Ford Model T 5893 wrench
This is a vintage Ford script double ended spark plug and head wrench. It is cast with Ford (script) on the top side. The bottom side has T-5893 and a B in a circle (I believe for Barcalo Manufacturing Corp.). One end is 5/8” and the other end is 1”. It has a little surface corrosion and no pitting at all. It shows signs of normal wear from usage.
Item E - Vintage Original Ford Model A adjustable wrench
This is is a vintage Ford Model A script adjustable wrench. It has the square end for removing the rear end plug. And ford script on the top. The wrench is in good shape with very little rust, but does show a bit of wear and tear of having been used.
Item G Vintage Ford Model T Wrench – Unique Ford Script
This is a vintage Ford Model T wrench. It measures about 5.5" long. On one side is
“2 circled M (Moore Tool Company logo) 1 1”
and on the other side is a very unique Ford Script (see photo).
Item H Vintage Ford Model T Wrench – Ford Script
“2 partial circled M (Moore Tool Company logo??) 1 1”
One end is 11/16” and the other end is 3/4”
Item I Vintage Wrench M-40-17017 Ford
A vintage M-40-17017 wrench in good condition. The wrench has a curved shape and is dual-ended, with a 1-inch open-ended wrench and a 11/16-inch six-point box-end wrench. This type of wrench came with old Ford tool kits. Sold as-is.
Item J Vintage Ford Model T Tool Kit T-5893 Spark plug head bolt wrench
This is a vintage original Ford Model T Tool Kit T-5893 Spark plug Head bolt Wrench. I believe this wrench was a part of the Ford Model T original Tool Kits, as the combination sparkplug & headbolt wrench. This wrench is the early style with the socket end. Later wrenches had the boxed end. The wrench is embossed on one side Ford in Script, on the other side it has an T-5893 and a M in a Circle, (Moore Drop Forging Company). The wrench is 11" long, one end is a 6 point 5/8" socket and the other end is a a 1" open end.
