Misc.V8 Parts ForSale
Andy
Kerrville
Texas
Price
Cheap
Offered is an extremely nice 33-34 wishbone. Straight, no rust, painted, no wear. $300
Model A wishbone. No rust. straight, damaged. The yoke are damaged from torch removal. I used to make goose neck offset ends. for the A bones. I like the size and shape better than other parts.Makes a great set of split bones. $100
32-34 perch bolts. Excellent condition. $125 a pair.
32-34 front shackles New $30
32-34 rear shackles New $30
Shocks. On pair no leaks. Still full. Work with stiffness. Bearings fine $200 pr
Another pair. The bearings are fine but they leak $100 pr
A-34 hot rod dead perch set up. I ran it for years. It requires a spring that is pretty flat when loaded or a stiff one. I put in a soft high arch spring and it did not work as well.
Comes with the dead perch with spring pin and a regular perch pin with shackle $100
56 Pickup 15x5 wheels Great condition. $150 ea.
Original 32 steering wheel. Great $200
Original 32 horn rod $100
32 original mast jacket $100
