** Misc. Ford Items **
47chev
New member
Chilliwack
Bc
Ford 6 cyl one barrel carb 144 170 200 250 $45.
2 Barrel carb off 302.
1985 Ford 302 Heads , came off running vehicle with low kms $150.
Also 85 short block 302 from running car low kms $150.
289 Shelby valve covers 302 could use some touch up, $100.
2 pairs of Stock small block ford valve covers $20 and up.
Shorty headers Small block Ford $60 , 260 289 302 351.
Energizer cam for Small Block Ford $100 , low km approx 1500km. 488 lift , 284 duration .
Small Block Ford 289 & 302 PushRods,length is 6.825" ( stock length).
5/16" Diameter, made in Usa. $39.
New double roller timing set, includes both gears and chain
A good quality made in Japan $25. SBF.
Original Ford steel flex fan , 5 Blades $ $25.
Ford C4 trans was removed from good running vehicle $195.
100 Amp alternator from 1985 Lincoln / Ford / Mercury 302 $25.
Rear Mustang sway bar came off 1969 or 1970 $50.
Rear Mustang II sway bar with brackets, fits 1974 to 1978 $60.
Maverick steering column with key and wheel $70.
2 Stock steel 14x6 rally rims 5 on 4.5 pattern. $50
2 Ford steel wheels 15x6.5 5 on 4 1/2 pattern $60.
Power Antenna in good working condition $40.
Lincoln Hydroboost BRAKE BOOSTER & Master cylinder combo $50.
