1930deluxe
How many thousandth can be removed from the head without a problem? Will milling the head cause a problem with the distributor shaft?
Not much! Stock pistons protrude above the block some, more if the block has been surfaced. You need a minimum of .030" of clearance between the piston and the head because the rods stretch when running, more so at high RPM.
You can also cut some of the top of the pistons off. In regards to Jim B. statment
I've just been through this issue while having the bottom of my motor rebuilt. My block had previously been bored out to the max (0.125") and decked quite severely. It had compression of 80 +/- 2 psi all round. The rebuilder said that the pistons were coming out of the block at the top of their stroke and fouling the (standard bore) head gasket. His solution was to take a chamfer off the top edge of the pistons.
Haven't re-installed it in the car yet.
On original parts, it's anyone's guess as to what has been previously removed. This actually the Question that begs an answer before any surfacing process. A new head would eliminate 1/2 of the unknown, actually more than 1/2.
