quickchange
Interested to know if anyone has run the transmission Mikes sell, Made in sweden, Always good to hear how new products work. Good Bad or Ugly.
I really don't like to "bad mouth" a parts supplier, but two years ago I bought one of those new transmissions made in Denmark from Mikes Affordable Parts instead of simply rebuilding my old noisey one with new USA parts. Lots of work pulling the rear end and so forth to install the new one. Problem is that it jumps out of high gear when on compression. I called Mike's to complain and they said they would send me another new one in exchange (no charge). They cautioned me of the importance of properly aligning the bell housing to the flywheel with a maximum run out of .005" With a machinists micrometer, my TIR was less than .001" Pilot bearing was new and so forth. Lots more work of again removing the rear end to install the new replacement transmission Mike's sent me free. All back together and I took it out for a tryal run. SAME DAMN THING! Still jumps out of high gear when backing off downhill or coming to a stop sign. I now just put up with it by holding the shift lever down firmly. It's O.K. when under power. Someday I'll "bite the bullet" and rebuild my old transmission like I should have done in the first place, and of course drop the rear end AGAIN to do so.
I know that Mike's is a very good Model A parts supplier and good and helpful people, but I wouldn't install another of those Denmark made transmissions if they were free. Sorry Mike.
True, but the sample size is 1.This is what i want to hear , 1st hand reports good or bad , This is what this site is about helping others , Great.
Curious, do their transmissions come with the shift cover, or are you using your original?
Evan - After returning the first Denmark transmission to Mikes, I had a lengthly phone conversation with their "expert" regarding the possible reasons for the problem. In addition to the bell housing alignment and condition of the pilot bearing, I was advised that a worn or sloppy shifting tower could also be the problem. So, prior to installing the second new transmission I completely rebuilt the shifting tower (reformed and ground the shift lever ball to proper size, resized the notch the ball operates in, new shift rails detent balls and springs). So everything Mike's advised was rebuilt or replaced. Then installed the second new transmission and it also jumped out of high gear on compression. I am not going to continue changing transmissions without confidence that it will work well, and due to all my work and experience with the Denmark transmission, I am convinced that there is something dimensionally wrong. To me, it appears that the high gear is not engaging far enough to stay engaged.
Over many years and many Model A's I have never had a problem with jumping out of high gear. The only resolution I would accept from Mike's now would be a financial credit for the faulty transmission I bought, but will not request it as "too much water under the bridge".
