Mic read on main
Are you sure you mike it right. That would be about .025 under not standard.
It is very hard to mike in the car, because it is hard to get the center of the crank.
thanks for the reply going to check again but sure this was it, crank is out. not a pro on reading Mic use the dollar and cent method and came up with 1.599. I guess this could be 20 and wore 5 but will check again
