This discussion about MGB or MGA shock modification for use on the front of a Model A Ford, there is a lot of information bits that just require a some compilation for me to deal with understanding. I have done my best to think through all that I have read and also add some info, and capture it all in one place. Going this route of replacing the shocks, I am not a point’s guy, I am a driver guy!
1) MGB and MGA shocks have been used to replace the expensive original Houdaille shocks by some creative Model A Ford owners with good results!
2) Some of the replacement after-market replicas are junk and Bill Stipe’s shocks, it appears he is putting people on a wait list to get on a list to make a set for them if he decides to do it.
3) There is another rebuilder source for original Houdaille OEM shocks that are really well done but 245 per unit + $100 core charge + shipping, but if you go this route, you have great rebuilt shocks that are original if you are into that. The rebuilder has a bunch in stock at
https://www.applehydraulicsonline.com/collections/ford-1928-1931
4) People who are interested in this British Armstrong shock application on a Model A have lots of questions. Which MGB or MGA shock to use? Rears of Fronts? What year car fits? What about price? What has to be done to make the Armstrong fit? Does the Armstrong shock arm need to be bent to align properly with the shock link? Once the shocks are installed, how do they work? Good? Bad? Do the holes align with those used for the Houdaille?
5) If I want to change the ride what are my options with these Armstrong shocks?
6) Lets take some time here to understand some things:
a. Model A Ford shock mounting centers for my 1930 are around 4 inches
b. I am currently contacting
http://www.nosimport.com/ . I talked to Jane about the use of these MGA and MGB shocks on a Model A and she knows they are supplying shocks for this purpose and the guy I really needed to talk to was Pete, and after the 4 day holiday, (Memorial Day) he just had no time. I will call him back in a week or so. I am interested in getting hole spacing as close as possible to 4 inches and I believe there is a hole center difference between the MGA and MGB model Shocks! I am going to pick the one that fits closest to 4 inches, or if there is no difference I will pick the newer (MGB) that were engineered for a little heavier vehicle.
c. What I did find out from Jane is the basic cost of a shock is $77.00 + $30.00 Core charge + shipping. (either for the MGA or MGB Shock! )
d. They can be made adjustable but……………Jane indicated the cost goes up considerably.
e. I know I am going to have to heat the shock arm and bend it to be in alignment with the bottom axle ball mount.
f. I know I am going to have to weld or bolt a similar ball to the Armstrong shock!
g. Pete also told Jane there is a shock absorber link being used by most Model A conversions to MGA/MGB shocks! I will get the name and supplier for that part also. Macs, Snyders or any other I am sure has the part.
h. It also appears by reading all the comments; folks are concerned about which year MGA or MGB rear shock to use. It appears that all that is needed to be known is MGA or MGB. The year is not critical. MGA’s were produced from 1955 to about 1961. MGB’s were produced from 1962 to 1980. Ordering these type shocks from
http://www.nosimport.com/ only requires that you specify MGB or MGA rear shocks and if you order a pair, they assume you want a right and a left!
i. Changing the ride – It would appear the el-cheepo method is to adjust oil viscosity! Jane did mentioned that those requesting the external adjustment, it was more for road handling and being able to change it as needed, but that the shock orifices could be set up for a 15% increase in added damping up and down. (at an added cost)
j. And a ball mount has to be added (welded/bolted) to the Armstrong shock arm to make the mounting be compatible with a Model A Ford shock absorber link! Mac’s sells replaceable steering balls that require drilling out the old one and welding in theirs!
k. Also, doing a bit more research on the weight of MG’s vs the model A Ford, The MGB car weight runs around 2290 lbs. The MGA car weight runs around 1990 lbs. My Model A runs around 2265 lbs. At Present, I have no clue what to do with this info, other than to ask questions when I get to talk to Pete. I believe damping ratio is the same for both the front and back of vehicles as they hit bumps at the same speed regardless of weight on the axle.
