Mercury Down
That picture in post # 20 looks like it’s pulling off center, I believe the pressure should be equal to all sides to get it to release.
Yes you are right but I tried the easiest method first thinking it would come apart as easy as the ones on the 52. Its like this one is welded together.
In olden times, we hooked a chain to one lug stud, looped it thru the removed tire, hooked the other end to another stud, and then swung the tire which acted as a slide hammer.
Was younger, stronger, and tool poorer back then.
Now-a-days, I have a slide hammer with a couple different flange adapters.
Have you got a slide hammer?
In my opinion, this is the tool for the job. I can't imagine doing the job without this tool....
I agree but I hate to borrow tools almost as much as I hate to buy one to only use it once. I'm considering Rich B's method above because all I have tried so far results in no movement.
Maybe check and see if your local parts store has a tool rental program.
O'Reilly's here has the flange and slide hammer for free rental.
If you are concerned with the studs; cut a couple chunks of 1/4 x 2 angle and drill both legs. Bolt one leg tightly to the flange and the chain to the other repeat on another stud and go to town.
Princess auto, the Napa of Canada, no slide hammer?
Yes, and I just found out my brother has one so I'll be borrowing that one to try out. I'm a little doubtful if that bearing will come out in one piece considering how hard it is stuck in there but we shall see.
