Mercury Differential
get a wire feed ralph, you wont regret it
I believe you are right. I'm still researching the Migs. Shopping a little and watching various youtube videos of them at work. I think the forums have pretty well talked me out of the cheaper little wire feed, flux core wire welders.
A suggestion. Once you have the floor pan in and the gas pedal located, weld two nuts to the underside of the pan and use machine screws to bolt it down.. Last a lot longer than using sheet metal screws. I did this when I restored my Tbird
Found some good heavy sheet metal in the scrap iron collection today. Not big enough to make a single panel for the driver side so I'll have to splice two (and a bit) narrow sections together. I think this metal is heavy enough I can weld it with the arc welder without burning through. It will give a good strong mounting base for the gas pedal.
Sounds a good plan but I'm not sure if there might be a part missing from the gas pedal. No sign of a base or any holes to attach it. Whatever it had originally might have disappeared along with the rusted section of floor.
On the 52 I came up with a crude but surprisingly satisfactory replacement. I cut a short of heavy rubber belting material. Screwed one end of it to the gas pedal and the other end to the floor. It seems to work just fine.
Hi Ralph, You must check out the Merc they have as a header on the Jalopy journal. Its cool!
Its a very nice 54 but I'm still stuck on the 52-53 style. Those chrome surround tail lights are the best part. Plus the Dagmars on the 53 of course :)
There was an old man that drove a 53 4dr sedan almost every day When I first moved to Elgin 40 years ago. Come to think of it the car was not that old at that time, Ha! It was a metallic sort of green with an ivory roof. Don't know what ever happened to it.
hmm... my 53 was a "woodland green" with ivory top. i was told it came from the town of Mackenzie Tennessee but I wonder how many were actually ordered that way?
I have spent a lot of time searching the net to find out the actual name of the colour combination on my 53. I know the 52 is a solid "fanfare Maroon" but can't find anything conclusive on the 53. My sense of colour is not that great and have a hard time with these charts on screen. So for now I'm just calling it green with a white top. If I had to make a guess I'd say Sungate ivory roof with Timberline green body. I've cleaned it up a lot since this photo but didn't have any outdoor photos after the clean and shine. Indoor lighting does not give an accurate view in my opinion.
Ok, maybe disregard my comments on the colours. I see the chart I was looking at was for 1953 Ford, not Mercury. Search continues.
Timberlane green and ivory sounds right. I can’t remember where I got the color from. It may have been from my 49-57 Ford parts book. I’ll check tomorrow if there is a section on paint.
I'm beginning to suspect that the plain old Ford paint charts are different to the Mercury, Meteor, Monarch paint charts. Have you ever seen "fanfare maroon" as a paint option for a 52 Ford? That is what my 52 Merc is. Code 95 on my i.d. plate but maybe its a Canadian car difference?
http://paintref.com/cgi-bin/colorcodedisplay.cgi?year=1952&con=y&model=Mercury&rows=50
