I checked the vacuum advance once I got it running about 6 months ago, it does work. It may not work correctly for now, thanks for reminding me. I need to replace the vacuum line. I also have an average of 105-ish psi per cylinder when I did a compression test.
As for the OD I verified all wiring is hooked correctly, every wire within the system is brand new now. It's not working though. I put power to the solenoid on the trans and it clicked. I also put power to the relay under the hood, it also clicks. I believe my kickdown switch is bad, it isn't in the best of shape. Aside from that I see no electrical reason for it not to work. Am I correct to think that the kickdown switch can stop the OD from working?
Currently with my OD engaged I get the typical free spinning. Once I replace the kickdown switch it'll either work or it won't. If it doesn't I'll go back through all the threads I've read and start verifying everything is correct on the trans.
Side note. I replaced my speedometer cable today also because the old one was making all kinds of noise and jumping around. Under 30 mph the new one is nice, quiet, smooth and reads correctly. Over 30ish mph it was worse than before! I had to disconnect it in a parking lot just to hear if my OD was kicking in or not.
