I just picked up a Mercury intake manifold w/backdraft carbureter. I'd like to find out about them, what year(s) they were used, etc.:
Manifold: Numbers on top - 8CM-6520
" " bottom - K080 or K0800
Carbureter: Automatic choke
Cast aluminum base
1G50 on top of Accel. pump tower
Venturi = 1.434"
"3" stamped in top 2-1/4" back from air horn
I thought about using the manifold on a stock 8ba with a Rochester 2GC carbureter. Is the bolt pattern the same? Will there be any benefit in either performance or gas mileage? Would combining this setup with a Chev. distributor make sense?
Carbureter looks good, is there any use for it?
Thanks,
Howard
Cast aluminum base
Venturi = 1.434"
Thanks,
Howard
