I think stopping ability is limited more by the small tire foot print (of large diameter tires) than properly adjusted and maintained mechanical brakes. Just my opinion.
John
John
Henry wasn't cheap. When you consider the number and types of parts required for a mechanical system versus a hydraulic system, the cost of mechanicals was probably more expensive.The only reason A's have mechanical brakes while Chevy and Plymouth had hydraulic brakes was due to the fact that Henry was too damn cheap to switch over! By the way, when you use dual cylinder master cylinders, you still have brakes in the event of s cut hose. In 25 years of driving A's with hydraulic brakes, I've never had a leaky wheel cylinder...what am I doing wrong?
Where I used to work , a street rodder friend of mine had a stock Model A, he wanted to know how to rebuild the brake system. I gave him the Les Andrews book for reference, a week later he returned it to me and said , that's to much work. Go figure!It all comes down to proper restoration!
I like the mechanical brakes on my Model A as they suit the dynamics of the car and encourage me to drive within it's limitations. There is no need for a more powerful hydraulic system in this case. With my modern cars I'll stick with the assisted, ABS, all round hydraulic discs that are linked to the road by wide, low profile, high performance tyres.
