Any one know of a Mechanical Brake specialist that can rebuilt my brakes system? I live in Southern California Los Angeles County or San Bernardino County. Seems that there are not many resources out here.
You can do it. It won't be a fast process but it will be satisfying. Randy Gross is a wealth of info, but I'm sure if you take your time and work with a local machine shop on the stuff you can't do. you can be successful. Backing plates can be sent to Snyders for rebuilding also
Here you go.
Mel Gross
Re: Brake Overhaul![]()
I really don't understand why more of you don't try us out for all of your brake needs.
We have cast iron drums, relined shoes. e bands.
We rebuild backing plates and can swedge our drums on your hubs.
Ask on this website and see how others feel about our product, quality of work performed, turn around time, and customer service.
Call or email if interested
Randy Gross
melmodela@aol.com
714-292-8660
thanks for the motivation. Is there a manual that I can buy to make sure Im doing it right? I will pay Randy a visit since it is not to far from where I am at. I have heard good things about this drums.
I'm in the middle of doing this job myself. I'm using the Red Les Andrews book as my reference. I'm also adding Flathead Ted Floaters, rebuilding the springs, steering, and front end at the same time. I'm using core parts so I only have to take the car off the road to change the old for new once the new is all done. This way my car down time is minimal. The Les book is pretty straight forward and easy to follow. I can try to answer any questions you have also. I have heard really good things about Randy also if he's close that would be a very valuable resource. Good luck on this
Of course it depends on how early your Model A is.If it's among the first six months of 28 it is an AR and you're into a whole new kettle of fish unless you want to upgrade your brakes to the "newer" style. It's very hard to get info and some parts for the single braking system (service and emergency brake combined) as well as the AR in general. If your car has separate emergency brakes than you have a late 28-31 Model A.
There's no info in Les Andrews book on the early brakes or anything else for the AR for that matter.
You can also buy the video called "Stopping on a Dime".
Tom where can I get that video from?
