Gene B.
Plan on taking just acquired 30 model truck to mechanic for maintenance and check up.
Probably going to convert to 12V
Drop oil pan to clean and check oil pump (try to figure out oil leak)
Change oil in transmission, differential, steering box
Pack front and rear wheel bearings( check brake pads- they function real well)
Modernize grease fittings
Truck has no shocks? Would you add modern shocks or try to find originals?
Radiator fluid clean ( water pump appears new)
Add air cleaner (like the KN upright to keep gas off filter) I live in the dust bowl
Check plugs and points
Any other suggestions? Main use for driving not show.
