JoeCB
Reading the current thread on point setting and spark advance, Raised a question... how to measure the actual advance on the car with engine running, like using a timing light as would be done on a modern car. This would require a degree wheel on the crankshaft, or at least marking the crank pulley rim in degrees.
Is the starting point at Zero advance when following the normal point setting instructions (using the cam gear pin) ?
And what is the design full advance at leaver full down and the distributor plate arm full stop in the distributor "window" ?
And finally, with a stock motor and modern fuel how much advance is optimal for high speed (50 MPH) driving.
Thanks
Joe B
Thanks
Joe B
