earbleeder
What is a good way to measure crank to cam centerline distance? I need a set of metal timing gears and want to order the correct size. Old gears measured about .0015" backlash with fiber cam gear and insert crank. Since then new insert crank installed. The engine is on a stand with the crank,pistons,and rods installed. I tried it one way and got a number close to what it's supposed to be but don't want to order multiple bronze gears if I don't have to.
Thanks,
Steve
Thanks,
Steve
