Mdl A differential, spiders, axles
switchkid0
Kansas City
Missouri
Guess I don't need a new diff after all. Not rusted solid, it just looked that way. Bearings should do the trick. I would still consider a complete rear axle, close to home.
I'm in need of a diff unit for a Model A, or at the very least, spider gears and yoke. I could be interested in a complete rear axle with housing and all,axles/carrier/ring gear assembly, or just about any combination you've got. Close to home is best, but if we can keep the shipping reasonable, any distance considered.
I can provide a used spider, choice of NOS spider gears or good used spider gears, the two piece gear case all of which should fit the postal Priority Flat Rate box. If interested I can quote prices. I have the other parts too large for Priority box and therefore more expensive to ship. I am in Massachusetts. barnstuf@comcast.net
