May 1928 Fordor Sedan
Neil Mylar LakewoodCA
Lakewood
CA
Price
trade?
Rare May 1928 AR Fordor - Sell body $4000 or complete car $8000.
Has hard to find original parts
Cowl vent
Left hand emergency brake
5 AR wheels with new whitewall tires
Correct windshield wiper
May 28 sparton ahooga horn
Banana popout ignition switch
Small hole water pump
Holley double venturi carburetor
1928 shock absorbers, with numbered arms
Original upholstery for patterns (has ornate trim pattern on doors & seat sides used in early production)
Red steering wheel
Nice original firestone door straps
Early ½” shaft starter and rectangular switch
Powerhouse generator
Rear arm rests
Correct May 28 round tube radiator
Laced radiator shell
Fan shroud
Original 2 blade fan
Solid front cross member
Correct distributor and cap
Correct oil pan
Original robe chord on back of front seat
Correct brake and clutch pedal
Rear drum taillight
Correct wide flat area front fenders, with rare front driver’s side welled fender (made only in May 1928)
Running, original May 28 motor
Correct AR front and rear end
Original front center bumper clamp
Correct headlights with original H fluted lens
Multiple disk clutch
Mushroom gear shift knob
Motor number A1260xx, built on 5-10-28
Has Briggs body tag showing it to be the 22nd Fordor Sedan made
Needs some wood replaced
Body has some surface rust spots, but no rust outs.
Cream paint color is incorrect
Originally purchased by a man in the Pittsburg, PA area who drove the car home and gave it as a gift to his brother on his wedding day, May 26, 1928.
Asking $8000 for complete car of $4000 for the body, hood, rear fenders, seats, and all door hardware.
Please PM any inquiries.
Neil, thanks for the detailed description of your 60-A. That's a real nice survivor. Mine was stamped 10-12-28, has original interior, motor, color also not correct. Hunt
Hunt, Thank you for your response. It sounds like our cars were made just a couple of days apart. I sent you a PM with some questions about your Fordor. I'd also like to find out if your upholstery has an ornate pattern to it and if there is a rope chord on the back of the front seat.
Regards, Neil
