On the Model A engine how much, if any, can the stroke be increased? Mainly wondering about space in the crankcase to swing a bigger crank. Would the maximun bore be about 1/8th inch oversize? I am familiar with the V8's but not so much the A. Thanks.![]()
My last engine was 0.125 oversize on the bore. I would offset grind a B crank to decrease the stroke not increase it, if I was going to change it. Think about it..
Thanks for all the responses, I was thinking about a torquey touring motor as opposed to higher RPM. Putting dimples in the pan is not a problem, but how much clearance is there between the rods and the camshaft for a longer stroke?
if you look at the hamb and a guy with then screen name crazydaddyo. you will see that he has had one or two cranks break after doing this offset grinding.
i think you are really just making things more complicated for yourself. just put in a mitchell or volvo overdrive and call it a day.
then its just bolt ons without sacraficing reliability
just my .02
tk
just put in a mitchell or volvo overdrive and call it a day. hen its just bolt ons without sacraficing reliability
just my .02
tk
just my .02
tk
