Most gaskets for the later ('49/'53) builds will not make the +080" oversize, they should make a +.060" however.
I have here Fel-Pro's and some early McCords, the fire-ring on the McCord's #6244R/L's ('49/'53) measures 3.265", and the fire-ring on the Fel-Pro's #7525B/7526B ('49/'53) is 3.255".
Fel-Pro has the bore size listed (on the above part numbers) on their "print" as 3.270", but in reality they actually do measure the 3.255".
The earlier Fel-Pro gasket's #7283B (24 stud '46/'48) does measure 3.270", so I'm assuming they simply carried the dimension "across the board" to the later pieces??
Thanks, Gary in N.Y.
P.S. Any gasket that measures 3.270" will make the +.080", the others are questionable at best! You don't want any of that fire-ring "hanging" in the bores if possible!
