Master cylinder
Jimbo
I'm putting disc brakes on front of my F1 and wondering what master cylinder to use. Any suggestions? I got kit from speedway. They recommend changing to dual reservoir. Thanks Jim cheaper the better
That's what I use. A GM dual with a booster, I have seen them in kits by Speedy. You can learn a lot about brakes on the HAMB, use the search tool and look around.
For disk drum manual,,,, 74 maverick ask for disk drum
for drum drum manual,, same thing only ask for drums.....
Use these on just about everything, good pedal feel and will lock em up if you fel the need.
I doubt your F-1 is heavier than my 54 Ford, so power is not really needed. I have front discs and no booster on my 54 sedan and it stops on a dime.
