master cylinder rebuild
LEAZER48
I rebuilt the master cylinder on my 48 coupe, cleaned and honed the cylinder (on bench vise), soaked the kit parts in clean fluid, installed the kit, added clean fluid to reservoir and waited for leaks, after a few minutes it started leaking through the front, what did I do wrong?
I usually rub a little grease on the edges of the rubber seals when installing into a clean, dry cylinder both master and wheel cylinders.
Thanks Jake, I took everything apart applied brake fluid to the parts put it back together, no leaks, I think the first seal was not seated all the way.
