Model a engine flows air at about 16o cubic feet per minute,stock a zenith flows at about 80 cfm,Stromberg 97/Holley 94 flows around 170 cfm.
See your engine as an air pump,use all the air it can pump creating useable atomized fuel.basically match cfm of carb to cfm of engine.doing this increases economy and power,the engine gains efficiency by using all its volumetric capacity to conduct useable fuel.
adding higher compression to the equation makes the combustion process more efficient,higher compression yields a faster more efficient burn.when you burn fuel at a higher efficiency rate your engine actually runs cooler.
I have never seen a marvel - not even sure they were available here ......
Synchro, I bought one at the Ballarat Swap last year. Actually thought it was a Tilly until I compared them more closely. Of course, it could have come off an imported car?
Am just curious,- was this not known in Henry's day? Why was the carb designed restrictive and not as efficient?
Wow, so there is one here! Does anybody know if parts are available for them or do Zenith or Tilly parts fit?
Sidetracking a bit here but in one of my sheds, I have a carb that looks like a Zenith but is a Japanese copy. From memory, It is KTK branded and made by the Tokyo Carburettor Co Ltd.. It looks like a zenith - does anybody know about those and do zenith parts fit? What drew my attention to it was the colour of the enamel on it - a deep maroon. I've never seen another one like it.
best resource in the US is Rennier Brothers in Michigan. Don't know about Australia.
Zenth/Tilliston parts can't be used on a Marvel.
It's a good carb.
