Marvel idle jet nozzle removal ?
harleytoprock
I'd like to remove the idle jet nozzle from my Marvel carb body to insure a good clean out and to level the bowl gasket surface. There isn't much info available on these carbs. Has any one ever removed this jet before? Does it just un-screw? Many thanks.
harleytoprock, do a search on this forum for Marvel Schebler carbs. There was a very in depth post made by one of our members covering everything about these carbs with an ample amount of great detail photos. You will not be disappointed.
Hello,
Yes the tube just threads out, I just used pliers to turn it, hopefully it will not be sieved.
