Marvel Drawing?
jeepguy1948
Does anyone know of a drawing of a Marvel carb (as used on the model A not the tractors)? I can’t find one anywhere.
The 'tractor' usage will essentially the same, as it is the same carb. Unless there is a different one that you are referring to. I have seen drawings of fuel/air flow but I think I have them at home.
Mike
I have not seen an actual section drawing of the Ford release Marvel Schebler. I have some sections of the carburetor that I've milled to show the internal passages of the idle circuit. They really are a very simple carburetor that might be why there's no drawings. The link that's floating around on here from one of the members that did some actual exploded carburetor photographs reveals a lot of the passages and is worth checking out.
On my website in a slide show, I do have all of the original owners manuals scanned along with a sheet that I put together with all the thread sizes.
