I have a problem when fuel tap is on carb does not leak but as soon as I try to start it I have fuel pulsing out the float bowl vent hole. It never use to do this when been used 10 years ago when I was regularly using it
I have checked float as thought needle might be sticking , replaced gasket between bowl and top and cleaned carb out.
If its needlle valve sticking open would it not flood and fuel flow out into airbreather ?
Is this the reason when I try to start fuel is coming out vent hole.
It is thanks to Jeff in another post that I was able to establish my carb is a marvel.
Any thoughts would be much appreciated .Wade
