markings
Sanddoc
Hello
I see a "52 flathead" on CL
he says it's a Merc, but gives no other info.
He does show a picture with a stamping of 52 in a square and a
2 H next to it.
Any Idea about the engine... it's been dissembled I did count
24 studs, and no extended bell-housing
thanks
The numbers don't indicate the year.
It's weird because of the head studs installed.
It may be a Merc. engine based on the 1CM stamping on the crank.
If the carb. and heads are original it's not a 52'.
The ****** will make a good boat anchor!
Good news is that crack is easily repairable with a new seat, new sleeve and pinning the block.
to tell you the truth I need another project like a need a hole in the head...
but would like to have a Flathead, but If I do go for it, I think the 8cm is the
one..
Just remember, the heads and intake, as well as all the other bolt on stuff is interchangeable. The big difference between a ford and Merc is the crankshaft. However in this day and age, the block is the most important part of the engine. A good one is worth it's weight in Gold.
