Purchased Speedway Electronic Distributor for my 1940 V8. Speedway indicated to forget instructions. First concern was no vacuum. Called Speedway and they said that distributor has a centrifugal advance and to plug the intake manifold vacuum port which was done. Second concern was alignment of new distributor. Called Speedway and they indicated to align rotor exactly as original. Rotors are quite different. Offset drive may align correctly. Decided to mark pulley for TDC. Removed fan. Ordered a 1.375 in 6 point socket to turn engine. Purchased TDC spark plug tool. Will turn engine first clockwise until it stops and mark pulley. Will then turn counterclockwise and mark pulley again when it stops. Will notch and mark pulley half way between marks for future timing determination. Is this a reasonable procedure or am I getting carried away?
