I am in the process of a project to convert my manual steering system to a modern style (No Slave Cylinder) power steering. First of all, I need to say that it's a Mercury (54) not a Ford and therein lies my problem. The problem is with the manual column shift levers. I'm using what's known as a Borgeson conversion kit. This set-up requires that the column shift levers be relocated onto the replacement steering housing after the original steering column sleeve is shortened to allow for the longer length of the new power steering housing. This kit is designed for a Ford column shift, which has the rod that operates the shift levers on the outside of the column. A 54 Mercury has a tube on the inside of the steering column which operates the shift levers. It will be difficult at best, maybe impossible to re-design and fabricate the Mercury steering column and make it work.
The best solution as I see it will be to either find a '52-'54 Ford steering column with the external shift mechanism or find a floor shift conversion kit. Thus far, I have not been able to locate either of these. I've only located a Ford truck steering column which I don't believe is the same as the car. So, If anybody knows where I can find a '52-'54 Ford car steering column with manual shift or a floor shift conversion please contact me!
Thanks, Scott
jones-scott@att.net
(317) 432-9190
Thanks, Scott
jones-scott@att.net
(317) 432-9190
