I was thinking of ordering the whole kit/cabuddle <SP>
Mike V. Thansk for the Info, that is great Info to help me get started.
I'm not 100% on changing, maybe leaning 80% towards converting.
I also understand keeping it original as possible and this is a reason for my hesitation, but what are the other benefits of 6V - help me understand (you never know you could possibly sell me on keeping it 6V)
I drive at night just fine using 6 volts and the original bulbs and excellent original reflectors. Good silvered reflectors and good focus are the keys to good lighting.
I can add turn signals with no worries about changine to a higher voltage.
QUOTE] Add turn signals? front and back. Are these mounted on bumper? Where can you do this? who offers these parts?
Keeping it 6 volts is so much easier on the starter and drive plus it keeps the car more original. My GPS works fine on 6 volts, but if it didn't then I could buy a 12 volt invertor, which changes 6 volts + ground to 12 volts negative ground. Or, like many others I could use a small 12 volt motorcycle battery.
Gadgets weren't a big thought
Most people seem to use the bumper mounted turn signals. Check the Model A parts suppliers for the turn signals you like. I don't have turn signals, but if I added them I'd use some that are seperate from the originals lights and also use some that require NO drilling of holes.I drive at night just fine using 6 volts and the original bulbs and excellent original reflectors. Good silvered reflectors and good focus are the keys to good lighting.
While I respect everyone's idea about what is correct and what you should do.. I'm also leaning toward a 12volt neg ground...
A few of those reasons are:
getting rid of the Generator and moving to a Alternators (no setting it, charging to little/too much)
light bulbs, battery and electronics all MUCH easier.
NEG Ground--- I even changed over my coupe that is still 6 volts to neg ground.
I looked over the idea for a while and it's a much easier process for me as I'm rebuilding a truck and need all new stuff anyway.
After all the reading/studying I would recommend the kit. For one you get everything you need and at once!!
The gentleman who said (it's hard on the starter) is partial correct, If you don't change out the Starter Field Coil, the starter will still work but with twice as much force as should be. Just as using the horn at twice the voltage or putting a Alternator on your old gauge..
Anyway to each his own, I guess. Which ever way you decide there will be people out there who will tell you that you should have done it another way.
Good Luck, D
Hi Wuudie, All good advice above with an obvious choice about whether to keep it simple and stay with the 6, or get a little more complicated with the 12 volt system. I'm going to throw something at you which will further complicate you decision: if you decide to go to 12 volts, you should seroiusly consider adding two features that I don't think you'll find in any of the literature. One is a relay for the high and low beams of your headlights as some of the fellows in the hobby have found that the voltage is to much for the old column switch and can cause shorting and/or welding. You can still use the switch to control the relays. The second is a two wire excitation system for the alternator to keep it from coming online with a bang at 1400 rpm. This is only important if you are using electronic equipment plugged into your electrical system on the model A (pertronix ingition jumps immediately to mind).
Also, consider fusing your car with a 4-block or 6-block set of fuses. A 12 volt short is alot more ferocious than a 6 volt short. Lots to think about!!! Good luck.
