Mallory YL springs
someone somewhere will have the remains of a set but good luck finding them summit raceing do a set that will fit yl/ym dissys but dont know if they will be right for you otherwise it back to old school ways with welder to add weight and grinder to reduce the weights lots of time required
Welding and grinding is a way to go but as I recall the weights in the YL are cast pot metal.
well then its time to get creative and make a set out of steel [use the weights as templets] done it before but it takes time lots of time
