V ventport Member Jul 16, 2023 #1 I have a Mallory Unilite distributor and a 57 intake and carb on my 56 T-Bird 312. What should I set the timing at, and should I change the plug gap from stock specs? The motor is stock with an automatic trans.
dmsfrr Well-known member Jul 16, 2023 #2 I'd set it between 6 & 10 degrees advanced then adjust slightly up or down to find what works best... http://ford-y-block.com/tuneup.htm . Attachments timing marks advance c.jpg 51.3 KB · Views: 16
