Rich/Alabama
Does anyone out there have any experience with using the Mallory #29219 coil with the unilite ignition and no ballast resistor? I read that it can be used that way without damaging the module. I have been using the 29216 coil and the Mallory supplied ballast resistor for the past 7 years without a problem but have recently installed a Holley 390cfm carb w/electric choke and would like to use the 12v source to the coil to power the choke. With the resistor, I am only getting a little over 4v at the coil and as Holley pointed out, it isn't enough for the choke to operate properly. Thanks,
Rich
Rich
