JSeery
"Note the regulator has a wire that is not attached. Generator is in sad shape. There is a rotor button in the distributor. Does that mean a points system?"
The missing wire is the battery wire from the starter solenoid battery connection side. If you have a loop ammeter, the wire goes from the starter solenoid through the loop on the ammeter to the circuit breaker panel. Then the same terminal of the circuit breaker panel connects to the far right terminal on the voltage regulator. If you don't have the loop ammeter and have the volt meter gauge, the wire goes straight from the starter solenoid to the circuit breaker panel and from the circuit breaker panel to the voltage regulator.
No, the rotor does not mean it is a points distributor. The style of the rotor might, I'm not that familiar with the older Mallory distributors. You need to shine a light on the distributor while you take to photos to brighten it up. Also, remove the rotor so you can see what is under it.
The wiring diagrams have fuse panel, but I think they switched to circuit breakers sometime during the model year, but not positive.
