flathead4rd: In Dec. 1919 I was having the same problem as you. I called Mallory Tech in ElPasso, TX and spoke with Bret Kugler. My engine is an 8ba on 12V.
He told me the following: "I recommend running a Mallory coil # 29219 along with an MSD part number 8214 ballast resistor. I would also run a circuit guard which is also Mallory part number 29731. In a later response Bret said: "The Unilite Module will last longer if you run a ballast. The Mallory coil (29219) has a resistance of 1.4 ohms. The Mallory module needs at least 2 ohms of resistance for it to function properly. 1.4 + .8(ohms) will give 2.2 ohms of resistance. A Mallory module needs to run at about 6 amps." What Bret told me surprised me as the 29219 coil has an internal ballast which means, I thought, that it did not require and external ballast resister.
I strongly suggest you call that Tech number and get up-to-date info. I also am using TAYLOR Spiro Wound 8mm spark plug wires. Let us know how you make out. PS: I eventually switched to Pertronix unit with good results.
I have a 292126 and a 29219 Mallory coils if you need them. Also have BERU ZS172 12V coil with 3.3 ohms primary resistance if you need it. The BERU is the equivalent of BOSCH
00012 coil.
Please, let us know how you make out.
