BUBBAS IGNITION
This started with a article in Vintage Speed Magazine and another post on the model A forum. http://www.fordbarn.com/forum/showthread.php?t=1787
I have installed three of these in the last few weeks and wow !!! What a difference.
Very little changes are needed for the T conversion, shaft must be cut off and advance rates changed and curved on distributor machine etc. Use the old Bosch lower end stuff and your off. I have this in two of my T's and they run perfect.
I use the TW timing tool to set the ENGINE TIMING at exactly 15 degrees btdc and curve for 20 degrees at 2000 rpm.
