Mallory conversion for flathead....
BUBBAS IGNITION
A good one to share from my monday customer work load. The old school mallorys are a very nice dependable unit and have a very adjustable advance curve with very little mods.
The chevrolet units are on ebay pretty cheap and thats what this customer did. He bought one on ebay and had it shipped to us ( see pic) After a total degrease , teardown and machine its back together and time for a spin....
Note that the advance weights and springs are adjustable by bending the tabs and they use a light spring for low speed and a heavier one for the higher range. Total advance is also adjustable ( this one was set at 12 degrees / 24 engine) and didnt need any changes.
Housing and shaft are machined to flathead specs and a new drive gear is installed with roll pin. The shaft is cut for either merc or ford and this customer is using a ford cover as shown testing for fit.
Contacts are in great shape ( i used a ultrasonic cleaner to kinda refurbish the contacts) and adjusted on the tester. Unit was spun on machine and had 24 degrees at 2600 rpm.
I used the two piece cap and the old brass condensor. Even though the condensor has a visable crack it tested good and we just clear coated it ti prevent any future moisture and should run with now problem.
Pretty neat way to get it done at a low cost. This one will be ran on 6 volts as well.
Conversion is $135 plus any actual parts you would need, ie : points,condensor,cap and rotor etc.....
I would look for a mallory YC or YL for a chevrolet engine. Basically any will do as most are in good shape. Try to find one with cap and rotor as they are hard to get. A straight up cap ( like the orginal flathead ) is available.....from NAPA...
I have an early vacume style for a flathead 8 lobe & a NOS 4 lobe Rev pol also for a flathead , is the rev pol 4 lobe any good ?
Thanks
Cheers
Tony
I have a new Mallory dual pt. distributor for my 59 AB. The car runs well at idle and at speed but it has poor gas mileage (12 mpg). This is even with using my overdrive (T5) and a 3.54 rear end. The carb (stromberg 97) was recently rebuilt. I am thinking it might be a mechanical advance problem in the distributor? Can this distributor be re-built to give me better gas mileage? Thanks
Thanks
Cheers
Tony
4 Lobes are good , you just tie the contacts together inside the distributor and they work fine. They were orginally designed to run a special dual primary coil with two leads from the dist , one for each set of points. Note the conversion above is a four lobe...
Thanks Bubba for refurbing my dizzy.
I have a good home for that dizzy in my 276 Merc flatty being rebuilt right now. I figured that shipping it direct to you when I bought it would save shipping again. I'm glad you could use the cool brass condenser. Thanks Gene
And of course there needs to be a "bubba" sticker on the dirt car as well....love that coupe. Shipped with invoice today...:)
I have heard that these dizzys dont fully advance until about 4000 rpms, you need to have it recurved bubba can do that for you
