30cabriolet
Does anyone have any suggestions on how to form a rear corner patch? I have a '30 Cabriolet and none of the poorly made patches out there match a cabby, so I don't even have a starting point. Both corners are gone at the bottom and the picture shows that they need work about 1 1/2" up. Do I need to make some type of form to bend the metal around? I do not have access to shrinker or english wheel, everything will be done by hand. I figure that I will bend a lip over 90 degrees to make the bottom and then notch the lip to allow me to curve a patch. After that, I don't have a clue as what would be the best way to go to form the bead. I will be tig welding everything in place.
I also added a picture of how my car looked the other day when my son finally got to ride "IN" the car instead of on it. I have been mocking up the body to keep the lines right as I have go about patching everything. So, while it is together before I start the bodywork, I have been having fun driving it around.
