A little bit of play is normal. Even new ones have a slight movement to them. Look at the bearings to see if you see any wear on them, or any pits. If you are thinking of replacing them, this is sure the time to do so. Another critical piece is how the end of the shaft looks and fits into the flywheel pilot bearing. That is the section that stabilizes the whole shaft. If the end of the shaft is worn, or the pilot bearing is, then it allows it to wobble when installed. It should be a nice smooth fit.
