Main caps fitting again
Mike/NY
Are the center and front main caps on the 81A block the same? They look the same and the take the same bearing. I have found some NOS caps and they all say "Center". Thanks.
Different. Sorry, The bolt holes are drilled different with an offset. That is to prevent getting them mixed up. I have a set of main caps. I don't know what they are from. Yours if you want them.
