ronzmtrwrx
I'm sure this has been discussed before, but I did a search and couldn't find anything. I am preparing to assemble my engine (59 style block) and would like opinions on main cap fasteners. When I pulled this engine apart, it had bolts with lock washers on all the main caps. Another block I have here (scrap) has studs and castellated nuts. Should I just use the bolts that it had, or remove and use those studs from the scrap block, or just order a set of studs/nuts from ARP?
This is just a mild street motor and won't see much abuse, but I don't want to risk failure if reusing what I have is sketchy. Thanks. Ron
