Tony G
I took apart a Model A engine this week that someone let rain get into the oil pan. After disassembly I found all of the bearings near perfect and the fit was great. The only damage is on the center main journal. Where the oil feed hole lines up from the block there's a small shallow 1/4 inch rust spot with shallow line following the bearing grove imprinted on the crank journal.Could the spot be ground below flush and then polished ?
Thanks for any input.
TG
TG
