Chuck Sea/Tac
Have an engine I just assembled and ran on a stand for an accumulative 30 minutes. Wanted to recheck lifters, and when I pulled the valve cover off , the center dam was full and poured oil onto the floor. Front and rear main feeders drain , but center does not. I pulled the crank back out, bearing was full of oil, and the feed tube clear. The parting line seems ok to me.
How does oil drain from mains ,and which is normal, drain or no drain.
Thanks
Thanks
