So, after a long hiatus, I'm finally getting back to working on my truck.
I've had the engine machined - old babbits removed (they were shot right square in the butt), and replaced with inserts. The machine shop gave me a set of grade 8 (5?) replacement bolts - anodized, with flat washers, and tall (taller than the castle nuts that were on it originally).
I assembled the crank & mains with the new bolts, but I don't like that the bolts aren't staked somehow. I am missing one of my original crenelated nuts from the mains, so I went off and ordered a new set of nuts from Brattons.
Got the new nuts in - thought I would reuse the flat washers from the machine shop along with the original bolts & the new nuts.
Problems, though - I did not take good enough pictures during my teardown. The tow rear main nuts (with washers under them) do not appear to go far enough down (it seems) to allow the holes to align for cotter pins.
So, here's the questions:
a) Which (original) nuts should have washer under them? All? Not the ones inside the crankcase?
b) Thoughts on using the machinists' nuts & bolts?
c) Would Lock-tite work as the staking compound - assuming I use the machinists' hardware? (I don't like relying on torque alone, especially where there's vibrations - but I've never used Lock-tite under torque)
Thanks in advance.
Thanks in advance.
